supra love
i found out i the hard way i have a leak with the new 2jz water pump. i bought it from the dealer and i also bought the 6" hose that came with it. there is a hole on the top of the pump and when you turn the engine on it leaks coolant.
the second picture shows the blue line i used to connect the two coolant nipples. i'm starting to guess that these should not be connected this way. did anyone else figure out what to do?
Autozone 2JZGTE waterpump was a direct replacement for my Soarer 1JZGTE. Cheap too.
Inline6Performance
If you have a single turbo, the blue hose should be capped off. That is a cooling line for stock twins. Just cap it off. The one under the water pump is the relief hole. It will only leak when the pump is bad.
agreed
