I didn't know that the 2JZGTE motor came in a 5 speed?? Is it true? Is this JDM factory spec?
eBay VVTI 5 Speed
eBay VVTI 5 Speed
Good call Matt on the flywheel. Must have been an auto connected to that engine originally...haha...MattOneDime said:Its real.. there are Aristo's with 2JZGTE's and 5 speed, they are pretty rare. That transmission you see is actually a R154, same tranny that comes in the Turbo MK3 supra only with a different bellhousing & shift mount..(Or same as 1JZGTE) That tranny is worth some bucks to the guys doing NA-T and GTE swaps in MK4's because it is way stronger than the w58 and bolts right into a JZA80 chassis. The attraction is it costs WAY less than a V160.. (although not nearly as baller)
Also, that engine is not from a Supra.. giveaways include: Oil sump/pan, wiring harness (see ignitor on other side).. AND the tranny didnt come on that motor, unless someone tried to run a flex plate as a flywheel!! lol
