11400-49088 SHORT BLOCK ASSY LIST 2730.74 COST 2275.00*****
15100-46052 OIL PUMP LIST 213.51 COST 157.88
04111-46094 FULL GASKET KIT LIST 394.13 COST 291.45
[includes valve stem seals and everything else you'll need]
00295-00103 FIPG PAN SEALER LIST 12.78 COST 9.36 EA X 2
90915-YZZD3 OIL FILTER V8 USA LIST 5.41 COST 3.96
00272-1LLAC-01 ANTIFREEZE RED LIST 18.95 COST 13.92 EA X 2
90363-12002-77 PILOT BEARING LIST 9.36 COST 6.92[ 6SPEED ONLY]
90402-16015 OIL PRESSURE SWITCH ADAPTER LIST 7.95 COST 5.88
15710-46020 OIL COOLER LIST 465.96 COST 344.56
[MANDATORY IF YOUR MOTOR HAD ANY INTERNAL DAMAGE]
15670-46070 BRACKET OIL FILTER LIST 85.54 COST 64.29 [ FROM NA MODEL TO ELIMINATE STOCK TT OIL COOLER IF YOUR GOING TO USE AN AFTERMARKET ONE]
ABOVE IS BARE BONES REPLACEMENT PARTS
16100-49846 WATERPUMP LIST 159.97 COST 118.29
13505-46041 T/BELT IDLER LIST 77.05 COST 56.97
13568-49036 T/BELT LIST 32.68 COST 24.17
13540-46030 T/BELT TENSIONER LIST 65.59 COST 48.50
ABOVE IS OPTIONAL ITEMS NEEDED[inspect and replace as needed]
13011-46051 TT RING SET LIST 202.85 COST 150.00 [ std only]
13101-46091 TT PISTON LIST 68.99 COST 51.02 EA X 6 [ std only]
13201-46040 TT CONNECTION ROD LIST 79.47 COST 58.77 EA X 6
13041-46013-XX ROD BEARINGS LIST 14.86 COST 10.98 EA X 6
11071-46020-XX MAIN BEARING #1 LIST 26.57 COST 19.66 EA
11701-46020-XX MAIN BEARING #2-#7 LIST 24.92 COST 18.43 EA X 6
11011-46030 THRUST WASHER SET LIST 35.96 COST 26.59
13401-46022 CRANKSHAFT LIST 849.74 COST 643.73 NS
11401-49715 BLOCK NAKED LIST 1973.48 COST 1725.00
ABOVE IS FOR REBUILDING YOUR BLOCK
There are 5 different sizes of main and rod bearings. I need the numbers off the Face of the block, rod caps and on the crank counterweights for correct sizing.
*** Factory Warrantee against manufacturing defects found at time of assembly. NO WARRANTEE on improperly installed, foreign objects in oil system,poor tuning,too rich, too lean, over-reved,forgot to put oil in, forgot to add coolant, leaking gaskets, too much boost, no break-in period, improper break-in procedures,clogged oil cooler from previous blown motor, contaminated oil cooler,improper torque of main / rod bolts,detionation,knock sensors not functioning, bad fuel MAP on your AEM/ MAP ECU/Greddy E-manage/HKS-VPC,improper cam clearances. etc etc etc
[shipping USA 135.00-225.00 range]
__________________
