Orubus said:Very sick...you never stop amazing me. Is this your first attempt at a 2j swap into an MKIII?
yeap.is he hmong too?
using 1jz hydro fan and water pump. you can also see that I'm using the 7m rad.how do you like the hydro fan?
the engine doesnt matter.cassio said:so can you actually use the hydrofan on an aristo 2jz?
you can put the sensor in the radiator hose.i think the fan mounts a little different thoughAGlobalThreat said:What's the trick to working the hydro fan on a 7m radiator?
