1 - 2 of 2 Posts
Needz moar rapes.
Im currently doing a 2jzgte swap (usdm) on my 95sc300 and I was wondering where does the white wire from ea2 (alternator wire from the supra harness) where will this wire connect to the sc?? (eb2) do i need to splice this wire somewhere else?
Is that the plug that goes right infront of the fuse box?
If so, that white wire should be plugged into the SC300 plug. Pull the pins out of the Supra harness. Pull the pins out of the SC harness. Re-insert the Supra pins into the SC plug. There's one extra wire. The extra wire is the black w/ red stripe. That wire should be spliced into the larger black/red wire. The white belongs in the plug in its one slot. I "think" its the middle of the three.
Alex
1 - 2 of 2 Posts
