1 - 10 of 10 Posts
DDDDUUUUUBBBBBZZZZZZZZ
Hi there, does anyone know if the Intake/Cold air intake system for MKIII's from 2kracing.com will work with an N/A or just a turbo? I want to get hard intake piping for my MK3. thanks
John
1983 Supra MKII
Supercharged
AFM Mod
K&N Style Filter
Aaron Garney Intake
62mm throttle body
410 LSD
2.5" downpipe
Hi-flow cat
2.25 Catback
'97 N/A Headers
306 [email protected] and 302 [email protected]
1987 Supra MK3 N/A
Stock
yeah i know, i just couldnt tell from the pic which one it was, thanks though, i think i'll go with your 94-00 civic tube idea
gotcha..what is the best way to go about making it a cold air? I know i can just get a 3" square adapter, but i want it farther down.
Well you have a couple of options. You can buy two (insert honda car here) intakes. Install the first intake like youve seen in all the pictures posted. Second purchase an adaptor and install it on the AFM. Then put the other intake on the afm and angle it through the snorkel hole. Then attach the filter and your done.
You can also pick up a piece of 3'' piping and install it between the two stock intake elbows to replace the resonator. You can also have a muffler shop custom bend some piping for you. Search for SupraNick's intake setup to see what I mean.
You also need to realize that your filter is going to get alot dirtier and a whole lot faster outside of the engine bay. I personally fabricated a heat shield and ran a dryer tubing to through the snorkel hole to the filter. That is enough to collect dirt in my engine bay, just imagine what an exposed filter must encounter. Just something to think about.
I had some help with 935 motorsport with a cold air set up for my 88 n/a, I spent about 80.00 for the HKS adapter, filter, and piping. If you want to check out a few pics I can email them to you. I dont know how to post pics here. My filter is under the head light and the resonator was replaced with staight pipe.
1 - 10 of 10 Posts
