1 - 1 of 1 Posts
Hi all,
First post on SF, so hello! I've been looking into turbocharging my 2009 Tacoma, 2tr-fe 2.7L with the r155f manual transmission. After more research and running numbers, I've decided I'd rather do a 1jzgte swap for the amount that it'll cost to safely turbo the 2tr-fe with decent boost pressure. I want to do a 1jzgte vvti swap out of the jzx100 Chaser, with a drive by cable conversion, while keeping my r155f transmission. I've read that the r154 bellhousing mounts to the r155f. I've also read that the input shaft on the r155f is 1/4 inch longer than the input shaft on the r154. I'm just curious if the bellhousing fromthe r155f will mount to the 1jz? If so, do I need any spacers due to the input shaftdifference? It's an odd ball build, and Ihaven't found alot of information on the topic. Any advice is appreciated, thanks!
1 - 1 of 1 Posts
