i took a huge dip in the road at about 90mph, after that I noticed my car was not running right. I had it in ttc by the way of ettc. Later on that night when I put it in sequential I noticed my 2nd turbo is not coming on. I am going to check the wiring for the ettc switch, to see if that may have come loose, I will also see if any of the hoses going to the pressure tank popped off, maybe check if the pressure tank is cracked or something due to the huge bottoming out that happened. Is there anything else I should look for or will those be the only explanations for the 2nd turbo not coming online at all?
