1 - 2 of 2 Posts
*I see you*
#21: O2 sensor signal. I unplugged the sensor once, could it be connected wrong? Or more likley a bad sensor?
#34: Turbo pressure. I hit fuel cut a couple times could that be causing this or more likely a dirty AFM?
#51: Switch signal. I have no idea..
Any ideas or help would be greatly appreciated.
Dr Wheelspin Rh.D.
Pull your EFI fuse for 30 seconds and see if any of the codes come back:
#21 if you unplugged it with the engine running or started the car with it unplugged it will store a code 21
#34 yes, you hit FCO
#51 your TPS is misaligned. Follow the TSRM procedure for realigning the TPS.
1 - 2 of 2 Posts
