1 - 20 of 23 Posts
What's the difference between 3 piece wheels and normal 1 piece wheels? Obviously, they're made of 3 pieces, but why are they so expensive?
Bigger dish? Can be made wider (hard to find wheels 10+ inches wide)?
Republican
Lighter, parts are replaceable, and look better
www.ziptieracing.com
no.
but i don't think 3 piece wheels are lighter. 3 piece wheels are usually custom made to your specs and not mass produced. that is the biggest reason they are generally more expensive.
Republican
For the most part they are. spun aluminum outer, forged center yea they are lighter, and stronger
Black is Faster!
SdSupraTT said:
of course it only comes in 19 inch, not good for supras... :(
And why not? I know of several... that roll on 19's... yea, you have to run slimmer profile tires=less traction, other than that... there is no problem. These companies like CCW/Volk aren't making these big (diameter) and wide wheels for hondas... who do you think they are making them for?
Vendor
i believe he is saying that because of the traction issue. its hard to catch grip on 19's...and supras have a bad enough time with traction.
Hello
I have the Forgeline RS3 3 Peice wheels. If you damage a 3 piece ie curb rash, you can replace the lip. Also if you want a bigger wheel, you put a wide body kit on etc, you can send them in and forgeline can widen them to your specifications easily.
Weights:
Stock Wheel with new tires: 47.5 pounds
Forgeline 3 piece with new tires: (265) 18*10: 50.5 Pounds
Jason
DONT HASSLE THE HOFF
My 19x11 CCW weights 22lbs and it's a 1pc forged wheel (strong as hell). And they go to 12" wide for sure but I think there is a 13".... Not positive on the 13" though.
These grip fine to me, not any worse than when I had the 18" Volks on the car.
Making a ComeBack!
It is also cheaper if u wants to change the design on the rim, u can just order just the centerpiece and replace the old 1. It cost me 600$ form HRE to go to a new design (each). Vs. the 5000$ u would normally pay for the set.
TRNSFST
Damn!!! 2400 dollars to change the center section. That's just as much as my wheels, total. Mine aren't cheap either, 18x10 and 18x11 two-piece.
I like the new CCW split spoke wheels they look great. Since I changed over to mustangs I noticed how similar they look to the Steeda Ultra-Lite II. I've seen these on a local black convertible and I'm in love.
Since seeing pictures of the CCW split spokes, I'm sold. I'm still waiting to hear back from John about the sizes available but I sure do hope he can do a set of 18x9.5 for me. Good shit guys!
Yes :) I ordered mine 1 hour after the first set in the US was ordered (for the Supra) but I think John said I was the first to recieve a set (woohoo!). But I sat on them for like 3 weeks before my tires got here though. They look so much better in person but the only thing about them that I don't like is the center caps (which is why I don't have them on). I'm hoping John will make a better looking one otherwise I'm going to have a machine shop make me some flush ones.
Caughron said:
Sean, are those the exact wheels that Ryan Woon put on the QS car? His are 1 piece as well?
They look AMAZING by the way!
1 - 20 of 23 Posts
