1 - 20 of 34 Posts
ok...this is my second try at polishing aluminum, and here it is. I used 80 grit to knock off the pits and raises, and casting lines on the aluminum...then i used 200, 600, 1500 to get it smooth...and then i rubbed it down with very fine steel wool..im not sure if anyone tried steel wool, but its GREAT!!! the aluminum shines like a mirror! check it out, i would like to know if anyone has tried steel wool to polish metals
Señor Member
Lighting and picture quality aren't too good. Got any other pics? I've never heard of anyone using steel wool to polish. Get some more pics posted! ;)
I would stay away from using steel wool on aluminum if long term shine is what you are going for. The steel (cathode) fragments bet embedded into the aluminum (anode) and promotes galvanic corrosion. It will turn dark gray in short order, especiallly if it gets wet (electrolyte).
I would buy some buffing compound (the hard stick type) and use a buffing wheel on a bench grinder to make is shine real nice. Then wax it.
SupraForums Sponsor
NegativeGeForce,
If you use a buffing compound the quality will come out MUCH, MUCH better and if you use the RIGHT buffing compound it will come out even better than that.:D :cool:
Later
for all that time and money you spent on materials, you could have spent 100 bucks and bout an hks 3k pipe wich flows better and is already polished and looks alot better
greasemonkey
yeah, the compound you want is tripoli. i used it on my dull enkei's when i got them. results can be seen here.
enkei's
only step you need to change is instead of using steel wool, get a grinder and mount a buffing wheel on it after you remove the gaurd. put the bar on the buffing wheel while its spinning till the wheel is black, then buff the pipe. it will be worth it i promise.
william
Discussion Starter · #14 ·
OK soo using steel wool is ok to get it to a semi-final surface, and then use a buffing compound to get it to the final product? The steel wool polishing actually looks very good to me hehe...ill try to test it with time
im sorry for the pic this webcam isnt cutting it, but here is a sorta better pic
No One Ever Listens To Me
NegativeGeForce said:
wow that looks freegin great dude...hope mine looks like yours :D
hey bro you gonna come to the huge dec 6th supra meet in clearwater? ididnt know you were in tampa....
and the 3k pipe loos good but those are bad pics...and lumpy yours is gorgeous...
i myself was going to polish the 3k pipe or whatnot bt because of the same reasons that bishop mentioned its gonna get replaced in due time...so im not wasting a ton of time on it so im gonna sand it up really quick....and then spray it with this aluminum paint....looks JUST ilke a polished surface
hopefully it will turn out nicely :)
neways hit me up bro!
1 - 20 of 34 Posts
