1 - 2 of 2 Posts
Back in Long Island =)
20amps the fuelpump uses? is this true
I heard the stock fuel pump used 30amp is this true? What can be swapped out in place of this thar runs lower amperage. I have A na allmotor supra mkiv do they use 20amps as well?? Thanks Brett
The stock mkiv turbo pump can pull around 20 amps. The walbro 341 only 11 amps. I doubt your NA pump pulls as much as the turbo pump, but I've never seen any numbers on it.
1 - 2 of 2 Posts
