1 - 8 of 8 Posts
Read Only
Hey,
Yes there is a lot of threads about the greddy 4 row installation however I cannot find pics of the hot side. The piping that comes out the compressor doesnt seem to fit at all, the front sway bar/alternator is in the way... Can someone post close pics of the compressor piping and where how the hell it goes between the alternator and front sway bar..
-Chris
You cannot use the 4-row piping with stock twins. You will need to reuse the stock piping on the turbo side to work on the 4-row. You can also purchase 3-row piping as that is what i did. Also do not tighen any of the hose clamps till you get everything setup and everything is attached on the way you like. Then you can put the hose clamps on as the final step. Get all the adjustments or tweaks to the pipe you can so that they all fit.
1 - 8 of 8 Posts
