1 - 12 of 12 Posts
boost life
can somone post up some pics of the na motor turboed with 4 runner cap on
is their any downside to using this cap and do the stock wires still clip on properly
i just installed mine a few weeks ago on my N/A supra in anticipation of going turbo, no problems just took the old one off, cut the extra metal, installed plugs based on clubna-t instructions.
edit: had to order the #2 wire for the extra length
2JZ MKII
Ebay manifold, PT-70 turbo, as you can see a 4" intake pipe still will not clear the cap. I had to switch to the 4R cap just to clear the bottom plug wire off the compressor housing.
you need toyota PN 19101-65040. 92+ 4Runner V6 distributor cap
AND
order a single 2JZ-GE #2 cyl plug wire. That wire will replace your current #1 plug wire which will not reach it's intended plug.
taken from clubna-t
From the land down under
Just a heads up that you dont need to buy that lead, just swap your #1 and #2 leads around and it will fit fine :)
You dont need to replace the rotor either.
Good luck
2JZ MKII
While this is true, it costs less than $10 if you buy it from a forum sponsor, never hurts to have new ignition parts. I did cap, rotor, wires, and coil and noticed a decent difference in idle mostly.
1 - 12 of 12 Posts
