1 - 20 of 41 Posts
Anyone know of an accurate 40 psi (or 3 bar) boost gauge?
The only one I see is the Stewart Warner 30 in/40 psi gauge. I ordered one, but the needle is not even zero'ed out, reading 1 in below zero, wtf! I am sending it back, but have not decided if I will exchange it for a good one or not.
A lot of these boost gauges are junk. A buddy has the SW 0-40 psi gauge, and he said it read the same as his AEM at first, but now it is 4 psi off at 38 psi! I also have heard bad things about Autometer - which makes a 0-60 psi gauge.
I dont have AEM or a way to datalog the boost, so I need a gauge!
Thanks,
Al
depends on what type of meter
mechanical will probably deviate after a while
electronic boost gauge (whihc is what the autometer nexus is) are pretty accurate through out the entire span.
0-60 psi boost guages... man not alot of those out.
Kwan Jul Sul Freak
Autometer makes 30psi and 35psi gauges. They also make 45psi vac/boost. I use Autometer Ultralites and they are spot on with what my Toyota ECU says as well as my Greddy Pressure sensor(s). Along the same lines, the gauge on my Profec E-01 reads that high.
Good selection of gauges here: http://www.egauges.com/default.asp
RoastBeefCurtain Commando
mechanicals as expected are so so at that level.
My Greddy only reads to 2 bar,, but my AVCR logs to 3bar. So above 2 Bar level I just go back and look at the peak recorded on the AVCR
Google some diesel truck boost gauges - I've seen 40 ad 60 psi gauges.
Dakota Digital has some very nice guages. Their odyssey series II are very nice. I have their 3-in 1 guage that has boost, EGT, and water temp, the boost guage in the 3-1 goes upto 80psi. They also have a single stand alone boost guageII that reads accurate to 0.2psi upto 100psi. They have solid state sending units. I saw these initially in Bradman's car and fell in love with them. When you turn off the car, they completely disappear.
http://www.dakotadigital.com/index....tegory_id=262/home_id=59/mode=prod/prd335.htm
Bad Karma Supra
Al, I have a 100psi digital boost/egt gauge forsale man! :) Spa Technique, I'll hook you up ;)
Jay
1100+rwhp member
I have a stuart warner gauge and it works perfect
Really nice but does it show vaccuum?
wastegate hose is pulled
I'm confused. You are going to run 40 pounds of boost without a way to datalog? You'll be using the stock ecu then? What piggyback is going to provide fuel correction up to 3 bar?
As far as boost guages, I have a fuel pressure guage for a boost guage. I could care less about vacuum though.
Why not just use a regular digital pressure gauge? They have ones available that will read up to 5000 psi. They are expensive the higher range and more precise you go, but they will work for your application.
Below is an example of a pressure gauge that you could use. It may not be the right one, but gives you an idea of what's available.
http://www.isotechna.com/Product.aspx?ProductID=18084
^^ damn that's expensive
i seen some people use boost gauges from a blower.
Some read 0-60psi
My buddies Cobra is off like 4 psi and he is running an automter. It makes you wonder how much boost is really hitting my engine.
Staats
1 - 20 of 41 Posts
