1 - 16 of 16 Posts
Hoping for around 400hp @ 32psi (lol) If I said that on my local forum everyone would say impossible to get that high with my setup.
I plan one running (30% 110octane) (70% 94 octane) @ 26psi for regular driving (32psi, 100% 110 octane, track)
Greddy T88
Greddy E-manage Ultimate w/ laptop built into car
Multi-Disc OS Giken
Tripple walbros (lol I know I know, incase one dies at high boost)
Going with 1000cc injectors (3 weeks) 720's now.
3/4" aluminum fuel line
Koyo radiator
Full 4" exhaust, aeroturbine muffler
AFPR set to 40psi static
Custom intake manifold, 90mm throttle body
P&P head
Complete Ferrea Valve train (Dual springs, 30mm exhaust, 33.6mm intake valves)
All gaskets and hoses replaced
Wiring redone
All new coolant hoses
Stock cams and gears until I retighten the head studs in 3 weeks then HKS 272's
Boostlogic crank pulley
Boostlogic turbo blanket (on monday)
Exhaust manifold and downpipe wrapped with insulation
3 bar map sensor
Currently clutch fan (modified to fit) soon to be dual 12" electric flex a lite
Tial wastegate and BOV
Innovate Wideband
12"x24"x3" intercooler (w/ 3" ss pipes)
Probably alot more but it's 4am and I am tired.
I started it up tonight, for the first time, started first crank. No smoke out the exhaust. Idles fine. I did noticed a dab "less than a drop" of oil on the front left of the head gasket right behind the waterneck . Don't know if it is leaking or I just spilled alittle. Or maybe the gasket needs to seat or something like that. The fan spins like a bastard at only 3000rpm so it will need to be replaced. After idling for 15min the temperature gauge barely moved. I guess it's because I poured the coolant in first then the water. It hasn't fully mixed yet. I should of mixed it before. It's still on last years tune so I will need to fix that soon. The exhaust is pretty loud, that muffler doesn't do too much.
Got 2JZ MkIII???
that is pure sex...awesome job man!!! really love it!!! :)
I blow up Toyota's
I hope you're kidding about the 400hp thing.
Nice set-up though. Glad to see someone else put a 1000hp turbo on their car too!!
Discussion Starter #9
I am going to be throwing on a 4" x 24" magnaflow muffler as well to help with the sound. The wastegate dumps into the down pipe as well.
Nice setup man! I would think that it would put down more than 400. Thats a big turbo also. Looks good and i look forward to more pics and video.
1 - 16 of 16 Posts
