Would there be much of an advantage to using the Acell 580cc injectors over the RC Engineering 550cc injectors?
Would the VPC w/ 550cc chip work just as well for the 580cc injectors as it would for the 550's?
Discussion Starter · #2 ·
DaveH is running the 580cc Accel's with his NA-T. I also believe he is running the 550cc chip. Remember you need the VPC chip for the MKIII and not the MKIV.
King of the NA-T's
Actually I'm running 750cc Accel's with the VPC/550 chip and a AFC. The 580's will work fine with the 550 chip. Just remember you need to modify the rail end of the injector slightly to get it to fit the stock rail. (see pic)
But will there be any advantage to using the 580's instead of the 550's? Around what psi and rwhp will they both max out at?
