1 - 8 of 8 Posts
Ok so I'm about to get my turbo sent into driftmotions for a rebuild, my car is between 8-9 psi. Will I hit fuel cut if I put a 57 trim ct26. No boost controller is on my car, I have full 3" exhaust, cxracing inter cooler and hard pipes and hks mushroom intake.
Although everyone's car may react differently, for mine it did not hit fuel cut till exactly 12psi when I had the same setup as yours. Depends how well the engine has been maintained over the years. I'd say you should be fine.
greasemonkey
Mine hit fuel cut about 10psi when I put the 57 trim on my 7mgte when I was on the stock electronics.
I hit fuel cut on stock CT 26 when I put Spearco IC, hard pipes and full 3" exhaust with the divorced DP on the car. Was a real disappointment to get a performance increase for a few seconds and then fall on its face. Had to do the Lex MAF housing/550 injector mod on short order after that.
I guess it really is different for every car. Mine hit at 12. Depends how good in shape your intake, head, fuel, and exhaust systems are.
Discussion Starter #6
My motor is freshly rebuild with cosmetic MHG and arp head studs torqued to 90. All new hoses everything.
Then you should be seeing up to 12. i had no boost leaks and I made it up to 12 on the 57 trim. You'll notice a BIG difference. Be prepared lol. I went straight from a stock ct 26 at 6 psi straight to the 57 trim to 12 psi. It's a whole new world lol. And then you get bored of it after a few months and then you move to a bigger turbo lol. Typical supra stuff lol. That's the one thing I hate about this car. Always thirsty for more power. Aka money pit
1 - 8 of 8 Posts
