6 speed "lock out" feature
682 Views 4 Replies 4 Participants Last post by  streetdream5520
ihave a 97 tt, and i am able to go in reverse w/out lifting/pulling lever. ibelieve something is wrong.is something broken lose ect?
isearched everywhere on net cantfind anything. thanks in advance
There's a metal plate that locks reverse shifting. Some people turn that plate around to disable the lock. Just remove the plastic cover and turn the plate around.
very odd with an oem shifter...seen it before on the b&m though.....check that plate for sure...maybe your tripod bushings could be shot as well, a stretch, but possible....
If you cant figure it out take a picture of your shifter area and we can tell you if it looks right. Probably that plates either gone or turned the wrong way. Easy fix..4, 10 mm bolts..
checked today the plate is on correctly arrows face to front of car
