1 - 20 of 54 Posts
I'll be going to the track as soon as the 7m swap is done in my '84. Hopefully the car will be done by mid may. Lookin to be in mid 14 range.
· 86.5 Turbo
:stickpoke
2damaxsupra said:
the gas price is getting too pricey...going to mission and drag race is going to burn a hole in my wallet. i am out for sure :(
come on and run some 16s 2damax, what are you afraid of. Its 81km from my house to the track. So I would go through about half a tank of gas including a few passes. You saying you cant afford to drive your car?
· ma70-7m=1JZ
My swap wont be done for a few more weeks, but I might come out just to watch or race my truck lol, I would be lucky if I coulc get a 22 sec at 60 mph lol.
Hank- The good thing about going out there to race is you can fill up gas for like $.20 cheaper than out here, which makes it worth going.
· 86.5 Turbo
too much water in the system, air in there?? Mine spat out some coolant from time to time out of the overflow when I bought it. I got a few air locks out of the system and it looked ok. then it came back over a year later....bhg.
before you start your car open the rad cap to check if its full.
IIRC, its $23 to race. could be $25 i forget.
· Newbe....I know nothing!
2damaxsupra said:
it only overflow at idle after when i used the turbo. I checked the spark plugs and i check oil and coolant on daily basis and there is not mixing in both oil pan and rad or overflow tank.
That is what my car did with the BHG no oil coolant mix just overflow. You my friend have a BHG from the sound of it.
If I can get a clutch in my car Ill come up and run on my street boost and pump gas, I may bring up some drag tires tho not sure yet.
Jeremy
1 - 20 of 54 Posts
