I know quite a few people have suffered from the problem where the shifter will not center when in neutral. It will return from the 5-6 gate to center, but it slops around between the 1-2 gate and center. The problem usually goes away after the trranny warms up.
You can see a technical drawing as well as correspondence from Toyota which discusses the possible cause and fix (IE buy a new bellhousing for $600):
Well, I'm here to tell you that the prognosis is not so grim. Here's how I fixed it.
First of all, here's what we're looking at:
The shift rod goes into that hole and rotates this contraption as you move from center to 1-2 or 5-6. As you move to the 5-6 gate, it rotates clockwise and pushes against that spring, which returns it to center. As you move to 1-2, it rotates counter-clockwise and depresses that plunger, which is spring loaded and returns the shifter to center. The problem is that the ID of the bushing for the plunger decreases for some reason and binds the plunger. As the tranny heats up, the aluminum expands and the bushing expands outwards, freeing the plunger.
As you can see in the picture, the hole for the plunger goes all the way through the bellhousing. The outside of the hole has a seal and a snap ring, which holds the plunger assembly inside the transmission. Here's what's inside the hole:
The Toyota letter explains you need to remove the snap ring, then destroy the seal by making a hole in it and prying it out. You don't need to do that. You can use a C clamp that is deep enough to fit into the bellhousing and drive the piston back into the seal and push the seal out. Use a socket or something smaller than the piston as a spacer for the clamp. Make sure you put a rag or something on the outside of the hole, as the spring and seal will come flying out once the seal clears the hole. Then finish driving the piston out.
No you can see the inside of the hole:
The bushing is a metal bushing with a grey coating on it, similar to what you might find on a crank/rod bearing. I found that it had a textured finish to it, similar to a hammered paint finish, but finer. The high spots on the texture were binding with the piston. I don't know if it originally had a smooth finish, and something caused it to "bubble" up. Without seeing a new one I don't know. The picture shows it after I fixed it, but you can still see a little of the texture. The coating is relatively soft, so all you need to do is sand it down to regain your clearance for the piston. Here's what I used:
I used a wooden dowel with 800 grit sandpaper. You can use a drill bit or anything round. Wrap some 800 grit sandpaper and smooth it out. Like I said, it's relatively soft, so it doesn't take much sanding. Get all the way around and check your progress as you go. I finished it off with 1500 grit.
Once you finish, clean out the hole, then coat everything with V160 oil and reassemble. Works like a champ. Don't know how long it will last, but it should last quite a while. It's a pretty easy fix.
my shifter does that too, but it goes away after few mins. of driving and warm up. it doesnt bug me to much , but i am glad to see a fix to the problem is it every gets worse.
Yeah, its not really something thats worth doing on it's own. But if you ever find yourself pulling the tranmsission to replace the clutch or something, it doesn't take much extra to fix.
Long post alert! :)
My car is an US TT, automatic. I’ve destroyed this transmission several times, it was last rebuilt less than 5K miles ago.
I’m not looking for any real power anymore, it is a single conversion but I have the boost so low I doubt it’s much higher power than BPU.
The last...
So the left side dash lights will not come on (Eng, oil level, and oil temp). A friend of mine said it might need to be solder and was looking for another solution on here. Also my speedometer bounces every time I turn it on never reads close to what I’m actually going. I replaced the VSS but...
Hi all :)
currently in the process of getting my supra back on the road and configuring a base map but having some difficulty with getting it running correctly.. it’s so close so any help to get it sortedwould be amazing
I’ve done some searching on here and whilst I’ve found people...
Hi I would appreciate it if someone would give me some insight on removing the air filter? I have tried to remove the clamps close to the air filter to see if I can pull it out but I don’t seem to have enough room to move it out and I don’t want to break anything so I appreciate your help or...
I just installed the Driftmotion turbo kit with a Borg Warner S366 and I just tried to start the car. it starts up and sounds normal, but once the RPMs start to drop down it starts to idle rough and once i try to give it throttle to keep it going it just chokes out the car and stalls. My...
