1 - 7 of 7 Posts
I don't think the 350z tranny is all that strong - I think there's a bunch of NA stock guys that had problems with it.
It would be pretty sweet though, since the tranny can be found for a few hundred dollars.
http://www.supraforums.com/forum/showthread.php?t=413913
not a six speed but MUCH stronger than the stock MKIV POS. The conversion will run you about $1300 plus clutch/flywheel compared to a v160 that is about $3000 if you're lucky plus clutch/flywheel. This conversion should be fully viable withing a couple months from what I'm seeing
with a thrust washer upgrade and the right clutch around 800whp from what i've heard
1 - 7 of 7 Posts
