1 - 20 of 20 Posts
Chrome resistor, GTE coils, 440cc injectors
Email: [email protected]
Phone: 8143975799
It's time to unload some of the treasure taking up space in the garage. Prices OBO include shipping, but if you are using PayPal add 3%
Chrome Resistor pack - WILL NOT SEPARATE DO NOT ASK - $200 OBO
'97-'02 VVT-i Supra harness. Part Number 82121-1B190. Not Aristo harness. Has some cut wires.
TiAl 38-44mm Diaphragm -
Aftermarket
6 Delphi 720cc low impedance, top feed injectors. Purchased from powerhouse racing and used for 500 miles. They use the resistor pack. Perfect condition : sold
MVP overhead gauge pod 60mm - $60 -> read MVP Overhead Gauge Pod
TiAl 38-44mm diaphragm: $40
OEM Parts
6 coil packs in perfect shape 50k miles : $160
Chrome GTE Resistor Pack 50k miles - WILL NOT SEPARATE - : $200 OBO
Twin turbo intake rubber pipe accordion:$50
440 cc injectors with rail and lower plenum runners: $100
Resistor bypass plugs : $15/piece
Power steering bracket : $35
'97-'02 VVT-i harness 82121-1B190 : $250 OBO
VVT-i coil packs: $sold
OEM timing gear - not VVTi - $40
OEM Cam Gears - $30 / pair.
Make an offer anything else you see
Are you selling that diaphragm? What is it for?
Yes - PM'ed you
It's off a Tial blow off valve or wastegate. Yes I am selling it just make an offer.
#1. Is it in good condition? No tears, or folds? #2. What tial blow off or wastegate? They're are different diaphragms #3.could you pm me a closer up picture? #4. what is the chances you also have the little set screws that hold it on the valve? thx
-pat
-pat
It's for a TiAL 38-44mm wastegate. Has a slight bend, but no tears or folds. It will function fine. Pics above in thread. It has 4 hex screws in the center. So yes.
Shipped out some stuff.
Still have the coils, resistor and injectors, cam gears, fuel level sender, etc.
Discussion Starter #8
Bump prices adjusted.
Discussion Starter #9
added new pics - sold fuel level sender and battery tie down
everything OBO
Discussion Starter #10
bump
Discussion Starter #11
Bump
Discussion Starter #12
Injectors sold prices updated.
I need the back Hatch shocks if they are operational and in good shape. Also need the White Fuse Puller in the Fuse Box in the Engine Bay if you have it.
Can do $100 + shipping on the coils if they're still available
Discussion Starter #16 (Edited)
Discussion Starter #17
bump
Discussion Starter #19
Do you have a working stock bov?
Do not have it - Still have the coils, chrome resistor box and other stuff I can't remember.
Discussion Starter #20
Added pics of Chrome resistor pack
1 - 20 of 20 Posts
