1 - 7 of 7 Posts
SF in my veins... sigh
"mount" is a varied term...
There is the aluminum part that bolts to the block... and it is different in all three cases.
Then there is the rubber part that bolts between the bottom of that and the subframe. The 87/88 7M ones are unique, the MKIII 89.5+ 1J and 7M ones are the same... the MKIV 2J.. no clue.
Then there are the subframe "slots" that this all sits in... and those changed between 87-89 and 89.5-92 on the MKIII Supra. The 1J sits only in the 89.5 and up slots.
Boost Creep.
The aluminum (or steel in earlier models) part that bolts to the block is (according to toyota) an engine mounting bracket. The piece that goes between the bracket and the subframe is commonly what is referred to as the mount. Toyota calls this part an engine mounting insulator.
51cards is correct, the "insulator" is identical between the later-style 7m and the 1jz. The early 7m used a vastly different type. The 2jz uses a related insulator (i.e. also silicone-filled), but it's shape is different.
IIRC, you can mount a 2jz in a late-style 7m subframe if you use the 1jz engine mounting brackets. Someone correct me here if I'm off...
HTH,
Brendan
The early 7M mounts are square and a couple inches shorter than the later round mounts. I believe the later model mounts are 6 inches long...being 1.5 inches of bolt on both sides, and 3 inches of rubber. Good luck finding these. I never could...Ended up making some.
1 - 7 of 7 Posts
