1 - 2 of 2 Posts
I have a Mike U. modified 1JZ harness and it has the 7M knock sensor plugs, which do not plug into the 1JZ knock sensors. Would using 7M knock sensors work?
Also, I noticed that the coil pack plugs from the 7M plug in perfect to the 1JZ coils. Would there be any reason that this would not work? In what order (colors) do the wires plug in?
I would try it, but I am NOWHERE near completing my 1J swap, so I was wondering if anyone has had the same or similar experience so I know what to expect.
Moderator, l337 M0d3r4t0r
I'm not sure if 7m snesors would work or even screw in.
The sensitivity maybe diffrent but i dont know.
as for the plugs if they fit just wire them up propelry and the plugs should work fine.
1 - 2 of 2 Posts
