1 - 4 of 4 Posts
hi could i get a quote for the following parts, thanks.
Oil pump driveshaft bearings-11022
vent hose- 12263
NA oil filter bolt- 15600A
All Core plugs as a set if available
Thanks again!
vent hose- 12263
Thanks again!
Oil pump driveshaft bearings-11022 $29.92 EA. in stock
vent hose- 12263 $24.68 in stock
NA oil filter bolt- 15600A $7.32 in stock
All Core plugs as a set if available ??? I'm not sure what you are wanting????
quote # Q542125
quote # Q542125
A Core plug set(freeze plugs) one of the P#s is 11431A, and i believe there are six of those, then 2 of 11432B, and 1 11431C. hope that helps. i would prefer to buy as a set if that is available, and in brass if at all possible?
There is not a "set" available. And I din't have different materials to choose from, only the factory parts.
96411-44000 x7
96411-43000 x2
96411-43500 x1
all are $3.33 ea. and in stock
1 - 4 of 4 Posts
