A coolant problem of course.
Symptoms:
- On a cold start, drive the car up to temp and its fine, then il be driving along and the gauge will spike to 3/4 then drop back down to normal in the span of about 5 seconds. Only does it one time, on a dead cold start after the car has warmed to normal temp. After it spikes I can drive it around all day and the gauge will sit perfectly normal.
- As the car cools off, it will push coolant from the rad into the overflow, until its full/over flowed, if I take the rad cap off the coolant will be down to about the top of the cooling fins, system has pressure when I take the cap off when the car is cold.
- Burped the system a week ago, cant get 100% of the air out, car takes forever to get warm, I actually put the rad cap on one click and drove it around the block to get it warm enough to burp.. im working on a hill, cap off, heat on max.
Rad has 10,000km's on it, Cap is brand new, Waterpump has 10,000km's, Fan shroud is on properly, Fan is working as it should, Heatercore is brand new, No mysterious leaks, no missing coolant. Only thing I have not changed is the thermostat(dumb). All I can think of is an excess of air in the system pushing the coolant out as the engine cools, or the head gasket is leaking exhaust into the system under load.. but the coolant/oil is clean, over flow tank does not bubble or do anything strange while its running and its also clean inside, it only fills up/overflows when the car is turned off and cools off to dead cold.
Symptoms:
