what is needed to swap in a 7mgte swap? do you need to swap the tranny? i know you need a computer, wiring harness, intercooler and piping, exhaust and mounts but is this all?
ok well i have lsd so thats checked off the listcheck around these forums. there's plenty of stuff to do research on. i haven't needed to post a thread in a really long time since everyone has already done what i want to know about. one thing to look into for ur swap would be a limited slip diff though. unless u already have the sport package nonturbo.
well thanks for these words, im not going to do it anyway, just for a few hours i thought about it but decided putting my 7mgte turbo kit on and vfac with injectors is just as good with the added compression :wavey:dude its a huge deal i did the same thing as you just jumped into it. I had everything i needed and the swap is a lot of work for a first timer a lot.
i know the turbo models go to 6200rpm so i dont really think the tach would matter unless its a different output which i highly doughti'm in the middle of doing the swap myself. aside from the harnesses, whatever transmition you use you need the applicable driveshaft, tachometer from the turbo model, exhaust is different but that is pretty much it off the top of my head. of course the intake, clutch fan, ecu, etc.
haha very true!You'll also need some beer.
well thank you for this! i have been trying to get to that point!WOW this thread is full of bad info....
This means that as long as you have a flywheel, clutch, tranny, driveshaft all from an NA your good or all from a turbo your good. You need to have those 4 pieces. The diff doesnt matter but you had better make sure you have a sports edition NA diff because those have LSD which means your not gonna look like a loser doing your peg leg pirate burn outs.
i am totally up to doing the resistors cause i have been working in electronics since i was 9. my dad is an electrition for south west gas.full of bad info???
besides the rev limitter issue everything else is fine. and replacing the resistors, unless you know what you are doing, is a bad idea. the average 16-20yr old mk3 owner doesn't have the gear to clean the flux, prep the board, make the proprer solder joint or even the knowhow to add resistors in parrallel/series. noone said anything about the flywheel, clutch or compatibility of transmitions i only mentioned the fact that the driveshafts are different.
don't get me wrong, i'm not trying to come off as being offensive and i appreciate your input you obviously know what your talking about judging by your other posts but totally dissing this thread is un fair.
sureawesome. i can send you pics of my pcb if you want?
