^yup heads are the same. only difference is the intake cam. turbo has 2 knock sensors versus one on the ge and the n/a's have high compression pistons. the rods are the same. gte's have oil squirters tho but if you ran a good free flow oil system that shouldnt be much of a problem. might also want to run the gte manifold if you switch to a gte ecu.
