Complete Japanese spec 7MGTE with all accesories/sensors, and wiring harness. This engine is a low miled "jap spec" motor that you see from the likes of K Wantanabe. The engine is complete and includes the ENTIRE ENGINE from the valve covers to the turbo, to the oil pan. Engine ran great before it was pulled. The engine harness is in tact and connected to everything. All you need to do is pull your old motor (if using it in a MK3), and drop this one right in. Guaranteed to run and not smoke.
Also available: all the electronics from the ECU and ignition system, AND A CUSTOM MK3-MK2 engine swap harness! I have all the electronics and wiring harnesses to make this engine ready for a MK2 conversion. I also have a Lexus AFM that will be included as well (to get past the annoying boost cut).
Pricing: the 7MGTE w/o MK2 conversion pieces $1300
for the entire package $2150
Stuff is located in SE PA, and I will be able to deliver at no charge within a 200 mi radius of 18103
Pete
