Any advice would be helpful here. I may have ruined my maf / 91 Turbo, after spraying out with carb cleaner. �� Another hard lesson here for a novice mechanic. After disassembly and light cleaning of my air intake. (turbo boot had a slight tear, so I wanted to temporarily wrap it to seal the air flow into the turbine) anyhow, took all hoses apart, wiped clean any dust from the insides and sprayed carb cleaner through the MAF housing, let dry. Changed the oil, and then re-assembly. Test drive and my guts were in knots, jumping and bucking and shutting off, rapid rev idle and no throttle response had me sick to my stomach. ugh. She ran about perfect beforehand. So, a little research took me to my mess up. Its been a few days and wanted to re-clean the MAF with cRC MAF cleaner, just once before buying a new sensor + housing. The cleaner says DO NOT use on my supra with the Karmen-Vortex MAFS. Any experience on cleaning one of these.
