I am building a 7m and i need to know if there is any prevenative measures i can take to prevent a BHG besides a MHG. Or possibly if there is any upgrading i can do to the cooling system.
Regardless of bigger is not better you need 720cc injectors and you can run 720ccs with an afc. Some of you guys seem to think you Know all the answers, but fail to realize that you need a combination of everything in synch to be optimum, but running lean on fuel is a certain inevitable death. 550cc injectors are for any one making 350-450 rwhp max, and 450 rwhp on 550ccs is cutting it close. Running anything under 720cc injectors is asking for a one way ticket to the rodknock life. Just make sure AfR's are not over 11.7 WOT if using an afc with not too agressive timing and you will survive. Many have done this and have made 600+ rwhp. Also again anything over 450rwhp really needs to be managed with a standalone. :1poke:hes tuning with a safc, bigger is NOT better. Things need to be balanced so fuel isnt added or subtracted excessively when using piggy backs.
If it where a full standalone i would definatly double up on the fuel available vs. needed.
good advice...tell him to get larger injectors than he needs and than tune with a afc. So now he can pull a TON of fuel and at the same time advance the timing considerably. that's the perfect way to get away from detonation!!!Regardless of bigger is not better you need 720cc injectors and you can run 720ccs with an afc. Some of you guys seem to think you Know all the answers, but fail to realize that you need a combination of everything in synch to be optimum, but running lean on fuel is a certain inevitable death. 550cc injectors are for any one making 350-450 rwhp max, and 450 rwhp on 550ccs is cutting it close. Running anything under 720cc injectors is asking for a one way ticket to the rodknock life. Just make sure AfR's are not over 11.7 WOT if using an afc with not too agressive timing and you will survive. Many have done this and have made 600+ rwhp. Also again anything over 450rwhp really needs to be managed with a standalone. :1poke:![]()
I like smart mouth know it all like you. You don't know shit about Supras and you actually think thaat you can teach me something huh. Well Mr. big mouth an AFC is not the optimum way to tune, BUT you can achieve a goal of 600rwhp to the wheels using it. I believe the famous Will Knealy did this and whupped many a cars like this never blowing anyhing. Pulling fuel, and making sure your timing isn't advanced over10 degrees will definitely achieve this goal.good advice...tell him to get larger injectors than he needs and than tune with a afc. So now he can pull a TON of fuel and at the same time advance the timing considerably. that's the perfect way to get away from detonation!!!
and detonation does not cause rod knock...poor oiling conditions does
OP, do not run 720's on an AFC. I assume you already know about torquing the head higher than factory spec as well as getting arp head studs (as opposed to oem bolts)
the key is STANDALONE. Its a double sided sword with a piggy back. If you can control timing, pull as much as you want with a piggyback. Other wise balance your setups needs.
I have yet to see a 7m that developed RK from detonation. You should blow the rings to pieces along with the HG and piston long before this..
