1 - 8 of 8 Posts
Just bought a boost controller and want to put my stock boost up a little is it safe to go 8psi with stock everything no fuel upgrades and stuff or will i need to do some modding to bump my boost to 8psi thanks everyone
Depends mainly on the condition of your 7m/fuel pump.
If it's old and tired upping the boost could kill it.
That said, 8psi is only 1-2 psi over stock so it shouldn't hurt anything.
My cars in decent running condition, not perfect i must say, but ive been running 12 for the past 3 months with no issues what so ever. Not to mention a turbo thats on its last legs.
DDDDUUUUUBBBBBZZZZZZZZ
You can do 11 or so safely I'd say. If you haven't already done intake and exhaust, do it first. You may then not need the MBC depending on your condition and the weather.
(◕_◕)
12psi max on stock maf/fuel. I run 14psi on high, low is 9psi. 680cc injectors /w lex maf.
I have a open element air filter and a 2.5" cat back with a flowmaster and i run 12psi. no problems. Have been running at that psi since i did the swap back in March. I hit fuel cut every great once in a while but i don't drive it hard that often. I have a Felpro HG with ARP head bolts
1 - 8 of 8 Posts
