1 - 13 of 13 Posts
One night last week my passenger side window got smashed in by some moron, and now I need a new window. I don't want to shell out a couple hundred bucks to a dealership so...
I'm wondering if the 87/88 passenger side window will fit on my 89? There is a 87/88 turbo in a junkyard near my place, and I could probably get the window off of it for cheap.
The body styles are slightly different from the pre-89s to the 89+s, but are the door measurements and specifically window measurements the same?
Any help is appreciated. Thanks in advance.
No One Ever Listens To Me
i also think it would fit....i have a 88 and a 89 sitting at my house right now....later today ill go and measure the window sizes and maybe that will give you a better idea.....
helps you jump higher
yeah I am about 99.9% sure they do, when I got my passenger window busted out I called around and a guy said he had a 87 window (I have a 89) and it fit, so unless he had a 89 and said it was a 87 it should work.
The 91 has a different motor, but the glass should fit.
Republican
WTF are you talking about, different motor? try a few mods, to bump the power, not a new motor....
Discussion Starter · #11 ·
I went and grabbed the window today. It took a while to get it out. Also I had to shell out $40 for it, but I'm not complaining since it's definitely better than whatever the dealership would ask for. I'll install it later this week, hopefully it is the right size as you guys have said. I'll confirm it after I install.
This junkyard has a bunch of pretty nice cars that I can see potential in as projects, such as a old school 300zx turbo, an FC, two pre-89 MKIII's, and a newer 300zx twin turbo. On top of that some turbo volvos... the turbos are TINY on the "turbo bricks".
Discussion Starter · #13 ·
It fits perfect. It was a bitch to install though since I lost one of the nuts that attaches the up/down harnessing to the window, so I spent a while looking for that, then said screw it and found a bolt that would fit. But it fits. ;D
1 - 13 of 13 Posts
