1 - 15 of 15 Posts
first off i bought this car for 1000$ with a 7mge(not installed) because he blew the old one its an 87 turbo body ya i know why put a ge in a turbo body i figured id at least use it till it blows since it came with the car. I made two ports for the knock sensors, got the cps, and coilpacks, and i got the gte electronics so it should work. and i have the r154 tranny with an act 6 puck sprung. ive been worknig on this car all winter i put new valves in and 2.0 hks head gasket. i got the motor in and all the wiring hooked up and it wont even crank. any ideas?
ok, iv,e been doin some investigating on that alt. fuse i took my fuse box out and checked each side of the alt fuse for shorts and the black wire has a short. I then pulled out every fuse and traced a short to the dome light fuse. i left the fuse out and tried to crank it. nothing. anyone? i need guidence this is my first supra i used to be a honda guy and i switched to the supra because i always wanted one and i got the oportunity to get one i basically rebiult the engine besides the bottom end and now im having damn electricall issues my worst nightmare!
ok i figured it out the wire on the starter was bolted to the wrong post switched it around now she fires right up! I feel like a damn fool. but it wasnt my fault the wire to the sylenoid was bolted to the wrong post so i hooked the battery wire up to the wrong side because there was nowhere else to put it. but now i have other issues,the temp gauge pegs on hot when i turn the key on could them temp sensor be bad or would the gauge even move if it was bad?
just get new aftermarket gauges, and sending unit for oil pressure. what code/codes are you getting?
Discussion Starter · #13 ·
so is it common for the stock gauges to not work? and i haven't checked the codes yet i'll do that tomorrow, im just glad it runs i'll post all the pics of my build as soon as i figure out how to get pics up on here so you can all see that i put together my first supra completely dismantled and i'd never even seen under the hood of one. thats how you know i had the burning desire to own a supra.
Discussion Starter · #15 · (Edited)
ground wire or maybe your alarm' im almost sure its one of those . just had the same problem.
ok, ive checked my grounds theyre all hooked up. which of the two was your issue? oh yeah, the temp guage was at halfway before i ever hooked a battery up, it rises to the red when i turn the key on before the car has even ran? if it was a ground which one could it be? and how do i disarm the alarm if thats my problem?
1 - 15 of 15 Posts
