I just bought a running, driving mkIII, its grey on grey, all stock (for now) 146,xxx decent tires, all new hoses, and new heater core, the car is in rough shape, the interior is faded dash pad is cracked, paint is faded, peeling, and it has a little body damage, but well worth the work. It runs strong, boosts fine, leaks power steering fluid horribly!!!
I have several questions about "retro-fitting" some parts:
Will a heater control unit from a 92 fit my 88 (plug and play) to replay the ancient grey chipping one?
Are the 92 tail lights a plug and play bolt on?
I have read the how to on the 90+ front bumper so I have that one down.
The trim around ALL the glass is chipping and falling off in places, It will all have to be replaced, but i figure most donor cars will have the same problem, I know toyota wants an arm and a ball for all the trim, is there another place to get all these as a kit?
Will the seats from a MKIV fit the MKIII with no modification?
Will removing the CAT set off the check engine light and make it run horrible like a newer car?
How do obtain the right cable and what all applications are needed to tune with a laptop? Is this really worth the trouble?
My Plans:
JE forged pistons .040 over
Eagle Forged Rods
T-61 Turbo
3 core IC
3" hard IC pipe
Electric Fans
3" downpipe
3" full exhaust no cat, not res
1mm o/s valves
2mm MHG
Dual valve springs
Titanium retainers
Clevite 77's
Electronic boost controller
Greddy BOV *LOUD*
Port & polish head
Tokico Struts/springs
F/R Sway Bars
F/R Tower Braces
4 piston calipers with drilled/slotted rotors
Fluidyne Radiator
Custom Intake manifold
Exhaust Header
Lexus AFM
550 or 720 injectors (depends on more research)
Dual Walbro Pumps
Shooting for 550 RWHP on pump gas, we will see.
*Will be daily driven*
My Plans:
Eagle Forged Rods
T-61 Turbo
3 core IC
3" hard IC pipe
Electric Fans
3" downpipe
1mm o/s valves
2mm MHG
Dual valve springs
Titanium retainers
Clevite 77's
Greddy BOV *LOUD*
Port & polish head
F/R Sway Bars
F/R Tower Braces
Fluidyne Radiator
Exhaust Header
Lexus AFM
Dual Walbro Pumps
