1.5JZ Turbo Supra
I need prices on the following, thank you in advance
Spark plugs x6 (gap required)
Wires
Fuel filter
Timing belt
Water pump
AT Transmission Gasket (please specify how many QT's to fill)
A/C Compressor
Alternator Belt
A/C Belt
plugs $6.08 each Denso plugs are pre-gapped
wire set $ 73.76
fuel filter $ 27.73
T belt $ 24.50
waterpump $ 96.03
ATM pan gasket $ 4 a drain and refill wil be about 4 quarts (dry fill about 12) RTTM
ATM pan drain gasket $ 1.33
A/C belt $ 9.32
ALT belt $ 16.12
P/S belt $ 8.56
Jeff
1-800-327-2087
Addicted to Boost
hey i have a question about the spark plugs? would u happen to know if the denso used for 7m and such r the same for the 1g-gte motor? if so u answered my question...thanks
jason
Addicted to Boost
ohh i already did the spark plugs , founbd out they werethe same as a 7m , got them from my local toyota...$80...big difference....the 1G isa 92 the 3 gen model w/11psi from a soarer
