1 - 11 of 11 Posts
AC o rings for all under hood lines. 4 lines total, so 8 o rings. Compressor to condenser and condenser to firewall.
Water hard line that runs around the block and feeds the heater.
Water union bolt at rear of head.
2jz valve cover bolts
Side mirror to body gaskets.
TENSIONER SPRING for timing belt
13505A
90099-14045 LIST .39 COST .30 EA X 4
90099-14046 LIST .39 COST .30 EA X 4
16268-42041 LIST 159.02 COST 117.59
90401-22004 LIST 5.57 COST 4.15
90105-06166 LIST .57 COST .42 EA X 12
NOT SOLD SEPERATELY FROM THE MIRROR
13505A
90507-18008 LIST 5.29 COST 3.94
SPECIAL ORDER ON THE 2 PIPES
dont worry Curt. I have a huge list ready to e-mail. I am merely attempting to get everything I need for re assembly in one shot. I would have the motor together already, but the cadmium plating shop has had all of my hardware/ brackets for 3+ months. I am going to go ahead an get as much together as possible since i am tired of waiting on the shop. I will get you the list this week. I need to find the p/n for a few more bolts that i have stripped out first...
Just for proof:
MAIN BEARINGS:
11071-43010-xx main brg # 1 list 20.97 cost 15.26 ea x 1
11701-43010-xx main brg #2-#7 list 19.62 cost 14.27 ea x 6 =$100.88
ROD BEARINGS:
13041-42010-xx rod bearings list 9.34 cost 6.80 ea x 6 =$40.8
Thrust Washers:
11011-43010 WASHERS THRUST LIST 40.70 COST 30.23 =$30.23
FREEZE PLUG SET:
96411-44000 list 4.06 cost 3.03 ea x 7
96412-43500 list 2.94 cost 2.18 x 1
96411-43500 list 4.06 cost 3.03 x 1 =$26.42
OIL PAN BOLTS (full set +2)
90119-08334 list .57 cost .42 ea x 26 =$10.92
lower engine to transmission bracket bolts (8)
91612-g1040 list .91 cost .68 ea x 2
91651-61040 list .39 cost .30 x 1
90080-11340 list .89 cost .65 ea x 4
90119-10315 list 1.14 cost .85 x 1
Intake manifold to runners studs/nuts
90119-08751 LIST .97 COST .71 EA X 7 =$4.97
Turbo oil return nuts (2)
90179-08012 LIST 1.89 COST 1.39 EA X 2 =$2.78
Turbo oil return studs (2)
92122-40818 =$?
Intake manifold runners to head studs/nuts
90561-60830 LIST .16 COST .11 EA X 11 =$1.21
Oil dipstick tube, both pieces o ring and dipstick
12142-42010 LIST 34.04 COST 25.17
11452-42010 LIST 22.01 COST 16.27
96721-19010 LIST 1.71 COST 1.27
15301-42012 list 13.06 cost 9.72 =$52.43
N/A oil filter stud
90404-20173 list 8.20 cost 6.06 =$6.06
Pressure plate bolts
90119-08782 list 1.14 cost .85 ea x 6 =$5.10
• oil drain plug
90033-41020 list 2.37 cost 1.76 =$1.76
3x oil plugs on passenger side of block
90345-51006 list .86 cost .64 ea x 2
90345-53001 list 4.94 cost 3.65 x 1 =$4.93
coolant drain on rear passenger side of block
90344-53008 list 3.20 cost 2.39 =$2.39
cps cover & 3 cover bolts
19121-42010 list 4.66 cost 3.44
93385-15014 list .55 cost .41 ea x 3 =$4.67
engine mount hardware
90179-12057 list 1.20 cost .89 ea x 2
90179-14041 list 2.06 cost 1.53 ea x 2
90201-12020 list .83 cost .83 ea x 2 =$6.50
timing belt
13568-49015 list 32.52 cost 24.05 =$24.05
exhaust manifold studs/nuts full set
90116-10025 list 1.06 cost .79 ea x 7
90179-10128 list 1.20 cost .89 ea x 7 =$11.76
• drive shaft to rear end bolts/nuts/washers
90080-10294 list 1.86 cost 1.38 ea x 4
90080-17239 list 2.63 cost 1.94 ea x 4
90204-10002 list .54 cost .41 ea x 4
• transmission fill/drain plug (2)
90341-18006 list 3.40 cost 2.51 ea x 2
• speedo cable directly off the transmission
83710-14800 list 11.77 cost 8.75
other stripped studs
oil plugs on head
valve stem seals
TENSIONER sPRING
13505A =?
clutch line retaining clips
heater union bolt
mirror gasket
76604 front mudflaps
76603-19155-XX LIST 119.29 COST 88.22
76604-19155-XX LIST 119.29 COST 88.22
AC o rings
13505A
I am debating on buying a crank kit (aftermarket) with all of the bearings setup for the crank undersize, or just ordering fresh bearings. If I go with the bearings, can I just get you the number off the back of each bearing shell?
Discussion Starter · #10 ·
Clutch line retaining clips 2
Transmission to block bolts upper
Starter to bell housing nuts/bolts
2 bolts that hold the fuel union to the driver’s side motor mount bracket
Two studs that hold the water neck to the head (and nuts)
Thermostat housing to water neck bolts 2
http://www.cygnusx1.net/supra/library/EPC/MKIII_NATO/291420/1201_2.html
2x 12263a
1x 12263
1x 12225
2x 12261
http://www.cygnusx1.net/supra/library/EPC/MKIII_NATO/291420/1106_1.html
“5” in the bottom left picture 2x nut & 2x stud
And that should be it (I hope). I will send the e-mail after work for the order... I am going to go with that crank set... I am pretty sure my crank has been re ground so the numbers on the block would be no good correct? Sorry about all of the parts....
92122-40818 LIST .91 COST .68 EA X 2
96991-10080 LIST 1.20 COST .89 EA X 2
90119-10019 LIST .39 COST .30 EA X 4
90179-10132 LIST .89 COST .65 EA X 2
91611-61055-83 LIST .16 COST .11 EA X 2
91651-40820 LIST .97 COST .71 EA X 2
90116-08243 LIST 2.43 COST 1.80 EA X 2
90179-08153 LIST 1.37 COST 1.01 EA X 2
90119-06485 LIST .80 COST .59 EA X 2
2x 12263a
96134-52600 LIST 3.26 COST 2.41 EA X 2
1x 12263
12263-42010 LIST 29.52 COST 21.83
1x 12225
12225-42010 LIST 25.46 COST 18.89
2x 12261
12261-42010 LIST 3.27 COST 2.42 EA X 2
92122-60860 LIST 1.00 COST .74 EA X 2
Allow up to 2 weeks to order/recieve/fill/ship this order.
1 - 11 of 11 Posts
