1 - 20 of 504 Posts
Unlimited Time Attack A70
Hello everyone, and welcome to my build. What you'll find here is a ground up Unlimited Time Attack build to my 92 A70 Supra. I've had the car nearly 15 year and has seen a few different configuration. Engine is built to handle 1khp and 10k rpms. All work has been performed by myself for just about everything unless stated. The extent of this build will cover ; engine, electronics, brakes, suspension, aero, rollcage, fabrication, interior, fuel, transmission and everything in in between. Every part of this vehicle will be reworked. The goal is full carbon widebody vehicle weighing in at 2700lbs with an output of 7-900hp turning 10,000rpms.
You can follow my website for detailed updates as well
www.projecthighrpm.com
IG : Native_nick
SPECS:
Head:
Cleaned
Decked
Mild P&P
3 angle valve job
Stock valves
BC springs
BC Ti retainers
BC 272 cams
Shimless buckets
Shortened Zinc ex studs
ARP thin wall ex hardware
Technico cam gears
ARP cam bolts
Custom -16an water neck
Block:
Carrillo pro h beams
Custom Diamond 8.5:1 billet pistons
.200 wrist pins
Billet 1jz timing belt tensioner
HKS timing belt
ARP head studs
ARP main studs
2% over balanced crank
Modified oil pump
ATI crank pulley
ARP crank bolt
Tilton 7.25" twin
Water pump delete
Power steering delete
Tensioner delete
AC delete
Bolt on Acc:
Precision 7068
BRE billet/sheet FFIM
90mm TB
1000cc ID injectors
Mechman 240a self exciting alternator
Ebay modified exhaust manifold
Davies Craig 150 remote water pump
Discussion Starter #2 (Edited)
reserved for killer selfies
My head right after the machine shop
Assembled head with shimless buckets, BC springs, retainers, 272s and technico gears
The technico cam gears are from a small company in Australia. They utilize the stock steel outer gear from a new set of oem gears and coat them in a hardened coating. Keeping the stock outer gear keeps the teeth from wearing like some aluminum gears. They then tap and make billet aluminum adjustable centers that use 5 sets of screws. I love them and think they're pretty unique
block all torn down ready for the machine shop
rebuilt the r154 earlier this year
Diamond custom billet pistons
I needed to find a way to attach my fans to my radiator. So I cut a piece of 4 inch aluminum tube in half, flattened it out and used that as my material. Here is the results
Discussion Starter #3 (Edited)
reserved for even more selfies
Wanted to revamp my old header wrap with some Ti wrap and reconfigure my drain for my turbo
new wrap
reserved
Since ive deleted all my drive accessories except my alternator I had to come up with a solution for water necks on my block and head. heres are the results
Everything was shaped and cut by hand except the drilling
raw materials
aligning my holes
Finally got my block back. Heres some pics of some of the parts haha
Question to suit.
Looking for some pics. ;)
Discussion Starter #6
pictures of my rod and piston combo :)
big big difference haha
This is a really neat tool that the machine shop made for me to clean out the oil passages in the crank so I wouldn't need to removed the detents
Block fresh back from the machine shop
decked, line hones, bored .20, oil passage balls removed and tapped for plugs
all masked off for primer and paint
Question to suit.
Nice stuff went into your build. I always thought you had to remove the fitting to clean out the sludge traps on the crank. Neat tool you have there!
Discussion Starter #8
Thanks, I'm trying to keep the quality on this build as high as possible. Yea the tool is really cool, use an airgun to blow air up in there and blast the gunk out. I've yet to use it, gonna put it to work tomorrow.
Discussion Starter #9
Fitting the intake and rail on.
Stripped the pain of the covers
Since I won't be running front covers I wanted to clean up my oil pump alittle bit and remove what wasn't necessary
sweet build! any particular numbers you are shooting for? what management are you using?
p.s. did you sell a set of mkiv wheels like 6 years ago? i feel like we met a long time ago and you sold these wheels to me.
Discussion Starter #11
appreciate it =) with the turbo I have now im hoping I can squeeze 700 out of it. The motor can handle alot more so well see, I may jump up a size or two and get a 6765 or something similar.
As for management i currently have AEM v2, once the motor is in I'll be getting a Microtech LT16c and custom harness .
we totally may have met but I dont recall selling a set of MK4s. There is a few other guys around here that have red mk3s.
Discussion Starter #12 (Edited)
My water pump and pump/fan controller came in today
Davies Craig Ewp150 rated at 40gph.
Painted the block with black enamel. Should turn out really tough.
Got some new key ways for the crank
Very cool build. I've always loved the idea of a high revving 1JZ. In fact I was almost doing the same thing to my 1JZ. The only difference being Tomei rods, as I didn't realize Carrillo made rods for the 1JZ.
However, instead of building the 1JZ head I opted to go with a 2JZGTE vvti one. Here's where I'm at now with the build. I'll be going with GSC S2 cams. The turbo I'm using is a 9174EFR
Discussion Starter #14 (Edited)
Thank you.. I love a high revving motor, there's just something about it. I really enjoy doing things differently as well so making an engine super zippy worked out great. Really trying to develop a great final product.
I love the idea of the 1.2. I too would would go the route you took over a 1.5. Looks fantastic!
Question to suit.
1.2 is legit!
You should ideally be going full dry sump for these high RPM adventures ;)
Discussion Starter #16
1.2 is legit!
Ohh most definitely. I've gotta get all the bugs worked out on the motor and tuning. It'll be in the works in the future
Discussion Starter #17 (Edited)
block is dry and ready for assembly
Heres a couple shots of the Mechman 240A self exciting alternator with 2.9in underdrive pulley for high rpm
obviously you work in a shop where at? lol funny as we also use wurth stuff and pb blaster haha, build is looking good! i got the same bc valve train/cams as u, my car has a nice lope at idle.
Discussion Starter #19
haha yea I do, I work at Mazda in Lynnwood.
I appreciate the kind words, hope to really showcase a nice final product.
good to hear, everyone loves a lopy idle haha. Since ive bought these cams I've found a different set that love to have but having to redo my shimless buckets rendering them useless is whats stopping me. But these cams will be just fine.
wow very interesting build thread here !!
very nice
1 - 20 of 504 Posts
