1 - 20 of 46 Posts
Yesterday mi ex-supra under the hands of my mechanic and tuner Cristian Penson
( C-Works shop in Dominican Republic ) and new owner Jose Rincon manage to obtain [email protected] of boost on his new forged 3.0 engine without nitrous.
They use a Borg Warner 75mm turbo from FAST_TURBO_USA turbo supplier from ebay.
I remember that we manage to make [email protected] with 720whp .... We think better numbers will came soon at 1/4 mile also.
great numbers.
What size exhaust housing?
T4 or T6?
Motec - Race Smart
Good numbers. I ran that same turbo in 2007 and made almost identical hp. Mine made 930whp on a dynojet. I think my best run was a [email protected] with that turbo, and [email protected] with nitrous on top.
Good luck with it! My only recommendation is to not push it much past 35 psi. I tried running it at 40 psi and it siezed after 3 runs.
-Darin
thanks Darin for that recomendation. Wow 152 mph good speed i think that we can go around 145 or 142 mph with the combination...... i`ll post the results monday ... thanks to all , thanks to you lucho :rockon:
is this on a dyno jet or which brand?
HKS 272
ULTIMATE DRAG TITAN MOTORSPORTS PISTONS
BC SPRINS AND RETAINTERS
MANLEY HEAVY DUTTY RODS
BW375
AEM tuned by Cristian Penson C-Works. Dominican Republic
I forgot to mentioned that the car runs with SUNOCO GT PLUS - 104 unleaded fuel.
926 whp unleaded !
WOW Lucho maybe I need to change from VP Q16 to GT PLUS and save some money...
Like 8 dollars a gallon to be exact from one another and i only want 750 WHP with my auto supra.
Discussion Starter · #18 ·
Discussion Starter · #19 · (Edited)
The numbers talk itself. [email protected] with the most economical race fuel in D.R. .. if you want to keep using Q16 or C16 it's up to you but is not need it.
Vendor
What is the motor octane on Sunoco GT Plus? I thought it was 99 or so...in that case - I wouldn't consider it safe for 34lbs but that's just me. Honestly even 104 MON isn't a ton for 34psi.
Good numbers though. And definitely follow Darin's advice in terms of how much boost it likes.
1 - 20 of 46 Posts
