1 - 2 of 2 Posts
Z
Okay so I have a 93.5 NA Red Supra.
I have kyb adjustable gas shocks and eibach springs. 17" wheels
The front is TOO low. It's been like this about...two years. Depending on some driveways i pull out of...tire air pressure...even some speed bumps i scrape the front (OUCH)
I have a friend that helps me repaint and touch up...but I don't think that's the answer foreveR!
AT THE SAME TIME i would like to add a Blitz kit to my car - I see some on eBay for like $300...I always thought they were in the thousand dollar range...When I do searches on Google i can fine the more expensive ones! But are they the same as the ones i see on eBay but just more money?
SO Here are all my questions!
1.) Where can i get a reliable Blitz kit - what type of material should it be made of?
2.) If i put that on my car - should i put the factory springs back on? I think the kit front lip is even lower...should i look into 18" wheels? 19"?? Factory springs AND bigger wheels? What size can i go up to without hitting the wheel well!
Any advice would be much appreciated!
How low is too low? there are tons of aftermarket springs that you can pick to your desired ride height, or even better adjustable coilovers. Stock springs will def. be too high, especially stock na springs. The blitz kits on ebay are probably copies. But im pretty sure the originals are also fibreglass (correct me if im wrong)... 90% of reasonably priced body kits are some for of fibreglass and will never be as strong/flexible as the stock urethane bumpers. Besides the fact that personally i think the blitz front end looks awful, the copies usually dont fit as well, but from what ive seen lately of some bomex/others, neither do some of the originals.
1 - 2 of 2 Posts
