Quote:
Originally Posted by Will2
The shop reports 575 hp @ 19lbs on pump gas so far. They still have to degree the staqggered cams, raise boost to 21-22 lbs, and final tune for pump, as well as a second map for VIP @ 30lbs. I expect to see an easy 600+ on pump I'll post graphs sometime next week if anyone is interested..
PTE 67/81
Greddy T-88 manifold
4" dp
Veilside Teardrop exhaust
Veilside Intake
Stock heads
Greddy 4-row
780 injectors
272/264 cams
AEM (finally found a good Unit AND Tuner..)
575 @ 19lbs pump so far, tuning incomplete
New dyno, after correcting some MAJOR mistakes in the fuel system.
610 hp @ 20lbs. Pump 93 , 11.5 a/r , Outside Temp 99 degrees , Humidity > 94%
Methanol and Race gas Tuning soon.... Thanks ALAMO MOTORSPORTS, for correcting the problems with the initial setup!
That's mine so far......
