1 - 20 of 24 Posts
Im A Fuking Ninja!!!
94 supra gte
Discussion Starter #2
Maintenance
water pump, timing belt, spark plugs changed (125k along with trans rebuild)
New starter (128k)
Head gasket (130k)
New OEM radiator replaced (133k)
02 sensor (2/2007)
Turbo installed at 134k compression the car compression test all cylinder (11/2008)
Chevron 10w30 syn, OEM filter, NGK 6097 plugs change (5-8-2009)
Compression test (5-8-2009)
1- 158
2 -164
3.-160
4.-160
5.-158
6.-160
Bleed brakes (6/2/2009)
New 275/35/19 Potenza Re050R (6/2/2009)
Redline HD Shockproof Differential fluid change (6/3/2009)
OEM total Type IV trans fluid change (6/3/2009)
Innovate Billet Catch can with breather (6/12/2009)
MVP polished upper radiator pipe(6/12/2009)
Wrap downpipe, flush transmission fluid again, installed EGT (6/18/2009)
Change oil with Valvoline Synthetic 10w30 OEM filter (6/18/2009)
NEW OEM Toyota Shift knob (6/19/2009)
NEW OEM center blank buttons (6/19/2009)
New OEN valve cover bolts, rear seat bolts (6/19/2009)
6/29/2009
OEM;
Timing belt
Serp belt
Water pump (full 2 piece housing and all)
Thermostat
Front Main seal
Cam Seal X2
Flush coolant with Toyota Red (30/70 mix) w/ water wetter
top of automatic fluid (due to dropping radiator for maintenance work)
OEM New Champion Toyota Floor mats (7/5/2009)
Eibach Pro/KYB GAB adjustable installed (7/27/2009)
Alignment according to Lance W Spec, brake masters (7/28/2009)
Remove old tint, Suntek (lifetime warranty) 35%front, 20% rear (8/5/2009)
-10an Fitting and oil return line installed at Densitsu (10/8/2009)
Kb Damper bracket, Polish Hood Strut/damper (10/16/2009)
Coil Pack Connector and pig tail, NEW OEM Purchase (11/18/2009)
Pig tail/ connector install
NGK BRK7EIX Iridium Plugs
Valvoline Full Syn 10W30 Oil
Toyota V8 Oil Filter /90915-YZZD3 OEM V8 oil filter
Clean Air Filter and Breather Filters (catch can and ITB)
Done (12/21/2009)
Painted Seibon TS hood OEM 040 White
(1-24-10)
Replace rear Sway bar with OEM, new end-links
(12-28-2009)
New OEM fog/parking light connector
Piaa H3 yellow fog
White LED parking lights, rewired parking/turn signal lights
(2-12-10)
OEM brake hardware kit (2-23-10)
Oil Change Rotella T6 (2-2011)
Oil Change Rotella T6 (8-2012)
Diff fluid drain and fill, Red line HD Shock proof (8-2012)
Boost Logic Transmission (1-2014) sent back and refunded
ATF Stage 3 built billet internals (5-2014)
FTI/Titan 3500 Stall Converter (5-2014)
Mishimotor 3 row radiator (5-2014)
Hi-tek B&M fan bar/fin cooler plus tube fin cooler (5-2014)
Greddy Power Steering Cooler (5-2014)
Driftmotion power steering braided lines (5-2014)
Oem Power Steering Bushings (5-2014)
Drain and fill all fluids, cooling, brakes, oil, diff. (5-2014)
NGK 6097 spark plugs (5-2014)
Oil Change Valvoline full syn (2-2015)
Anymore specific pictures request please feel free to ask or PM me to discuss over the phone
Is the title clean or rebuilt due to accident?
Clean title and in hand, I mentioned the accident to be upfront and since it is on the carfax
Discussion Starter #8
Some more pictures of the car and wheels
Discussion Starter #9
As requsted non "edited" camra phone pictures off of my galaxy note 4 taken just now
sweet looking ride...have a feeling this will be gone soon GLWS
Discussion Starter #12
Thanks.
Bump OBO
Discussion Starter #13
Bump OBO
Discussion Starter #14
bump
Discussion Starter #15
Bump
Discussion Starter #16
Bump.
Discussion Starter #19
haha I bet you would. small finders fee if i can get this sold asap
Discussion Starter #20
buyer couldn't come up with the funds, BUMP
1 - 20 of 24 Posts
