http://cgi.ebay.com/ebaymotors/Niss...2c1QQitemZ320382653121QQptZUSQ5fCarsQ5fTrucks
o
95 Nissan 240SX se, Pearl white with blue interior.
The car was built from ground up by a reputable performance shop that builds high end imports and race cars. It's in extremely clean condition and isn't some hacked up high school project, It's a professionally built Street/Drag s14.
* ENGINE
* Real 2jz-GTE Turbo Motor Swap
* USDM Cams
* 31x12x4 Huge FMIC
* Borg Warner S366 ETT Turbo .92 T/4 Exhaust Supports 900 Hp
* 3 Inch mandrel Bent Exhaust And Down Pipe
* TCS Eliminator Kit From HKS
* Tial 50MM BOV Tial 44mm Wastegate
* TRANSMISSION
* Mikes Racing Transmissions Ultimate TH400 With Transbrake 1200 + Hp Capable
* PTC 9.5 Inch Double Anti Balloon Plated Converter
* B&M Pro Stick Shifter Installed In Factory Location
* Custom Steel Fully Balanced Drive shaft
* Deep Sump Low Temp Aluminum Pan
* Dave H Billet Adapter/Flywheel setup
* Big Volume High Capacity Transmission Cooler With Fan
* REAR END
* Custom Infiniti Q45 Conversion
* Custom Q45 Hubs Upgraded With 11/18's Moroso Wheel Studs
* Samson R200 Big Volume Diff Cover
* 30 Spline 6 bolt R230 Axles
* Subframe Was Completely Gone Through All New Bushings Made From Polyurethane
* 3.53:8 Gear Ratio Good For Track And Street Driving
* Fully Adjustable Chromoly Rear Camber Arms With Heim Ends
* INTERIOR
* All Stock Interior Panels Look Like New
* Full Interior All Seats Intact Very Nice
* Auto Meter Ultralite Gauges Trans-temp, Oil-pressure, Boost, EGT, Water Temp
* All Interior Lights/Amenities Work
* Radio Bezel Is New
* Has A Kenwood Deck And Sony Speakers
* FUEL
* 255 Fuel System For Motor
* 550cc Injectors
* Stand-Alone Self Contained Fuel System For Nitrous
* Aeromotive Regulator Another 255 pump,Aeromotive Filters For Seperate Cell
* NITROUS
* NX Carbon Fiber Lighting Solenoids
* -4 Trunk Feed Line For Nitrous
* -4 Teflon Fuel Feed
* 10lb NOS Brand New Nitrous Bottle High Flow Valve With Bracket
* Bottle Blanket
* NX Super Shark Nozzle WET
* SUSPENSION
* Kyb Adjustable Struts
* Adjustable Camber Arms
* New Hubs Front And Rear
* New Rack And Pinion
* Brand New Weld 15x 3.5 and 15x8 Pro Stars With New GoodYear 28x9 Slicks
* MISC
* Large Aluminum Radiator With Dual Fans Runs Cool All the time
* I Have The Grill It's Just Out During Pics
* Makes 460 Rwhp On Pump Gas 17 Psi Through The Unlocked TH400 No Nitrous
* Weighs 2700 LBS
* Has A TransBrake Will Make Full Boost On The Brake.
* Car Will Work Anywhere Hooks Hard Street Or Track
* The Car Can Street Drive Anywhere In The Heat
* Has 5000k HID System
* At 20 Psi The Tune Is 11.5:1 Always Runs Starts And Drives
* Handles And Stops Great
* Very Quiet Cabin Wise
* Over 30k Invested Everythings Done Correctly It's a turnkey Drag/ Street Car That Always Surprises Domestics, Everything On The Car Was Overbuilt To Handle Hp From The 2JZ engine To the Fully built Th400 And Rearend.
As With All Used Items This Car Is Being Sold As Is With No Warranty
CALL OR EMAIL ANYTIME
661-233-3069 [email protected] 15.5 k OR TRADE VALUE OF 27K Or trade for newer dodge diesel no junk 04.5-07
o
* ENGINE
* USDM Cams
* 31x12x4 Huge FMIC
* TRANSMISSION
* REAR END
* INTERIOR
* FUEL
* 550cc Injectors
* NITROUS
* Bottle Blanket
* SUSPENSION
* MISC
* Weighs 2700 LBS
