1 - 11 of 11 Posts
1995 Lexus SC300 NA-T
15lbs = Numbers coming soon.
60' 2.315 / 1/4 13.441 / MPH 111.52 / 11.2lbs spike to 13.6 in 4th 10.5 AFR
BL 67 p-trim Turbo Kit/2mm Greddy HG/HKS SSQ/VPC/S-AFC/HKS EVC5/Zeitronix Wideband/550cc/Walbro FP/TT Front Brakes/TT Rims/3 inch DP/Electronic Cutout/ACT 6 puck clutch
*New Toy*
Now...Whitesupra94
*New Toy*
not bad. I'm liking the trap speed.
If im not mistaken...you should be able to crack 12's with that knd of trap speed. Work on getting your 60' times lower and I don't doubt you'll be in the 12's.
Good job and good luck,
Bob
Rocky28072 said:
Get some tires and work on that 60'. Trap is definitely high enough for some mid 12s atleast.
I am. I'll be getting some 275's here soon and Im going to try different launch point. That run was me dumping the cluth at 5300rpm, needless to say i spun real bad 1st and 2nd.
We'll see when I turn up the boost and get the tires! Should be fun..
Josh
Bob
I should be able to dip in the 12.60's or so with ~1.9 60ft.
Thanks man. Ill post again this up coming friday night..
Josh
I ran a 14.103 on 5psi in my '96 SC300 a few months ago.
With bald 275 Eagle F1s and clutch drop/slip at around 2700RPM (stock clutch), I was able to get a 2.1 60'
My trap was 99.1 MPH so it was probably one of the best times I could have squeezed out of that setup.
I guess what I'm getting at is that with some decent tires and a good launching technique, you could really get those 60' times down and run some 12s.
Nice setup by the way!
~Alan
Josh
5300!?! Lower the revs and work on that 60' time.
1st Lieutenant Team BEYAW
nice job man, and your 60' was almost as bad as mine were :D i would say lower the RPMs and feather a bit for traction, other than that, pratice is all you need and you will be cranking out the 12's!
Discussion Starter · #10 ·
mogallo said:
10.5 AFR?? Is it just me, or is that a little rich??? Get TUNED man!!!!
Nice runs!!! You'll break into the 12's!!!
I am now. I got tuned last night, 11.7 AFR from 3k- redline. Also im running 18lbson pump :) FRICKIN INSANE. Traction problem sometimes in 3rd, lol
Josh
MkIV Pilot
Josh
WHP???
I'm am going to run 18psi daily, and was told to expect NO LESS than 450whp with my setup.... we are thinking it will be close to 500whp.....
1 - 11 of 11 Posts
