1 - 7 of 7 Posts
I have another question about the NA's seeing im new to this. I read all boards and cant seem to find any info on the 97-98 VVTI Twin turbo supra engine. I was wondering if this would be any deifferent than a normal tt into an NA swap. I do believe that its a OBDII? How would that work anyone know if anyone has done it? Thanks for the research help.
I have have a 98 VVT-i na supra. Correct me if I'm wrong but I'm pretty darn sure that VVT-I was only for the NA's. Don't think there is such thing as a factory vvti twin turbo engine from toyota.
1 US twin turbo supra didn't come with vvt-i.
2 J-spec cars harness has a different lenght (shorter) then the us-spec cars. This is because the J-spec cars are right hand drive.
3 if you want to swap a vvt-i engine in to a us-spec car you will have to look for a us-spec (longer) harness suitable for that vvt-i engine and its ecu. (I don't know if it is possible to get one in the European market. I don't think you will get it).
4 if you want to swap j-spec tt engine into a us-spec NA supra, better go with a non vvt-i engine.
1 - 7 of 7 Posts
