Okay I’m about ready to smash my head into the wall. Can anyone tell me if there is anyone who makes a different ratio ring and pinion for the 200mm diff. I recently took the diff out of my car to fix a leaky seal. When I bought the car I was told it was a full turbo conversion but I felt that...
Hi
I have bought a new A/C kompressor as the old one was leaking.. When i mount the new kompressor, do i have to pre-oil it, or will it automatik do that when i go to a shop to fill the A/C system up.
I have bought this one :
https://www.rockauto.com/en/moreinfo...YDatlTJtDY8%3D
I bought a pair of seat belts recently from a member, the passenger side seems to retract and extend well, however the driver side is locked, it moves about half an inch when pulled on. Do these need to be mounted and plugged in to unlock? from my understanding the gear mechanism and ball are...
I've been tinkering with the idea of running a DBW throttlebody on my stock intake manifold. Bosch makes a range of universal dbw throttle bodies, and a company called TAARKS (from down under) makes an adapter plate for the Bosch 68mm to the factory VVTi intake manifold:
.....it looks like...
