1 - 20 of 25 Posts
I was looking around for pics of repainted 97 headlights. Due to flaking of the paint inside. Does anyone have pics of a flat black color? My car is black and I am wonder if it would look better flat black instead of the stock '97 headlight color. Any ideas? I tried searching I found one or two pics. But none as a complete headlight. Thanks
that tutorial is more for buffing the lense. The inside where the projectors are next to the rings..the paint is peeling there. I wanted to see some pics of housings that were painted black. Thanks
iSketch Master!
no he posted the tutorial is for ravan who was talkin about needing to bake them. That's not needed because they are glass headlights it's needed to soften the silicon sealant on all the types of lights so you can pull them apart. You could use a heat gun though, prob safer.
I think I have seen some black housing lights. They dont look too bad IMO. Maybe i can find some for you.
Alex
Mamba Still On Top
Alex
I won't give out the color code, sorry makaveli200369. Send them to me if you want them done with the color I use.
I recommend baking when disassembling, as the lights are heated uniformly, whereas a heat gun heats segments only and could lead to warping when separation is taking place.
Discussion Starter · #10 ·
So in your opinion did they look better then the stock '97 color? Its the same black base as the color of my car so it would match. I would leave it as a flat black and not clear it so it looks a bit tougher. I will tape off the chrome rings when I spray it. I wonder if it will look nicer matching in color. Kinda like how the Ferrari 360 or new vette headlights are matching the paint.
Thats cool MD. I was planning on taking the back housing to the paint shop to have a color matched to it if I didnt go with the black. Thanks.
Discussion Starter · #15 ·
so what do you guys think..will it look better using the exact paint color code used to repaint my car. It will be matching black. Or should I try to repaint it the stock '97/98 housing color?
Gunmetal wheel paint works pretty well. It looks a lot like the 98 housing, but personally I like the flat black, I think that's the direction I'm going to go. It'll match the rear tail lights from the pre-97s... which I have. :)
Discussion Starter · #18 ·
anyone have some bigger pic of the black housing on '97's and if possible on a black car. any pics will do though
Mamba Still On Top
Ravan17 said:
can anyone tell me if the plastic lights can be repainted?
The clear plastic? It can be but I would leave that to a body shop. :)
1 - 20 of 25 Posts
