1 - 2 of 2 Posts
I have a 88 supra turbo my a/c cluch is not kicking on the relay is good and the wire to the a/c ampifiler is good I can ground the wire and the cluch comes on I dont know if one of the sensor is causing it or what the heater work good in auto mode and manual
Discussion Starter · #2 ·
I found out what the problem was to night it was a shorted coolant temp switch I will order one tomorrow I alow found out that I have a leak on top of the compressor so I will also fix that
1 - 2 of 2 Posts
