21 - 40 of 43 Posts
where did you get the motor from!!?
PM me if you dont want to say on here
Beats and Rhythm
You are so damn lucky.:agreed:
Discussion Starter · #23 · (Edited)
I got a TON of people asking me where I got it from. Here's what i'm going to do:
I'll find out where this company got it from without throwing out any red flags (i dont want 300 people calling because then they'll jack up the price for everyone) and then i'll tell you guys which warehouse it came from. I'll talk to them tomorrow (friday) Let me know if anyone has any better ideas.
Also, I torqued to 74 lbs on a 1.2mm MHG. Is that enough? Any other advice? Is watter Wetter ok for this engine and the turbo? Thanks
What did you guys think of the pics?
thanks. and i just wanted to know for future reference.
water wetter and purple ice is alright.
and for the turbo it doesnt hurt anything cuz it just goes into a chamber and recirculates.
Discussion Starter · #26 ·
I paid $1100 + tax. This included a leak down test, and a 6 month warranty on everything but the turbo (which is ok because I have 2 spares ;) )
And it came with a turbo that looks really good. I dont know how well the turbo will hold up yet though.
And then they brought it to my house at no extra charge.
I'm really happy that the block looks bored out though . . . consider this a 3.2L Supra Turbo :)
How well would the "shimmied wastegate" work if I have a 3" down, test pipe, and cat back, port polish, etc . . . would i see any gains? or is it just for those who have few or no mods?
Discussion Starter · #28 ·
No, its just 83.020 mm Bore It has .020 pistons it looks like though
How should I have the machine shop bore out the turbo elbow?
Grumpy Old Man
.020" would make it 83.5mm bore and give you 2989.9 cc's so not quite the 3.2L you thought ;)
I wouldn't bother shimming anything until it's in and running correctly.
so u torqued it to 74 ft lbs wiht a MHG and stock studs? u'd be much better off with a STOCK headgasket and ARP studs
Discussion Starter · #36 ·
new bolts are out of the question right now . . . i spent too much money already. i should have invested in some.
so do i torque more? or should i stick to 74lbs?
Grumpy Old Man
Originally Posted by Reg Riemer
Recently I purchased a pair of new head bolts from my local Toyota dealership. One bolt from the 1995 Supra 2JZ-GTE engines, as well as a new bolt from the 7M-GTE. I then contracted a local certified engineering metallurgical company to perform tensile strength tests on the head bolts to compare yield strengths and torque values.
I have lab data reports based on the ASTM A370 tensile test, giving tensile strength, yield strength, ultimate load, yield load, as well as deformation data and maximum tightening torque values for the head bolts from the 2JZ GTE and 7M-GTE engines. Some results of the test are given below.
7M head bolt is: 12mm-1.25mm thread pitch {Property Class 10.9 grade 8} yield strength=147,353 PSI... tensile strength=160,550 PSI... ultimate load=70,198 N... % elongation=17... % reduction of area=66 2J head bolt is: 11mm-1.25mm thread pitch {Property Class 10.9 grade 8} yield strength=148,948 PSI... tensile strength=162,581 PSI... ultimate load=68,997 N... % elongation=19... % reduction of area=66
The metals used in the head bolts of the 7M & 2JZ engines are identical in metallurgy +/- manufacturing S.P.C. This is a good material; it stretches smoothly in the plastic region of the curve before it snaps.
By calculating the unit strain for each of the different areas of bolts based on the average yield strength, the following total elongation numbers were calculated. The 7M bolt has a total elongation of .0134" {.3399mm}, and the 2JZ bolt has a total elongation of .01093" {.2775mm}.
By comparing the elongation differences of the bolts, related to the corresponding different thickness of the aluminum in the engines cylinder heads, and allowing for the total length of the bolt shank plus 50% of the length of the threads, the only apparent difference is that the 2JZ bolt has 36 percent more thread than the 7M bolt does. The 7M & 2JZ bolts appear to be designed with the same steel to aluminum expansion stretch theory. I believe the bolt designs are different only because of the different ratio of the bolts metal area versus the thickness of the aluminum cylinder heads the bolt is designed to hold down. The torquing procedure for the two head bolts is also different, as is the head gasket
Toyota service manuals say that the 7M engines head bolt torque specification is 52 to 58 ft. lbs. According to my findings the 52 to 58 ft. lbs. specification for the 7M might be too low a torque value to keep the bolt in acceptable tension, not to mention the normal compression of the head gasket after time. As mentioned earlier many 7M engines that experience head gasket failures have many head bolts that can be removed from the engines failed cylinders by hand, or are very loose when removed.
My calculations show that the 7M head bolts when torqued to the factory specifications of 52 to 58 ft. lbs. is in very low tension related to the bolts actual yield curve. Calculations based on my test data show torque values for the 7M head bolt could be as high as 68 ft. lbs. to 72 ft. lbs. without putting the bolt into the plastic region. On a cold engine this extra torque would allow more tension on the head bolts after the head gasket compresses to normal operating thickness.
Many Supra owners that can afford it are upgrading their 7M engine to the expensive HKS stopper type metal head gasket for the 7M engine. This gasket comes in a number of different thicknesses. My Company stocks the HKS gaskets and I ship them all over the world. The HKS gasket will hold well to over 20 PSI of boost over 400 hp as sea level with upgraded fuel and turbochargers. The factory head bolt torque may be satisfactory with a metal head gasket since metal head gaskets do not deform as much as the soft OEM gasket used in the 7M. I would still recommend torquing the bolts to 72-ft. lbs.
21 - 40 of 43 Posts
